Авторегистратор HD, по случаю!
По случаю продаю свой регистратор, у меня пару месяцев, работает исправно.
Technical Specifications:
LCD screen:2.5LTPS(4:3)
Camera lens: 130 degrees A+level degrees high resolution lens
Language: English,Germany,French,Spanish,Italic,Portugal,TC,SC,Japanese,Russian
Video: 1080p/720p/480p(1920*1080P interpolation ,1280*720 30FPS)
Video format: MJPG
Resolutionr:5M/3M/1M
Photos format: JPG
SD card slot: SD UP to 32GB
Microphone: Built-in
Capture mode: Single/self-timer(two seconds timer,five secondstimer,ten
seconds timer,)and sequence
Frequency: 50Hz/60Hz
Television: NTSC/PAL
USB interface: USB 2.0
Power:5V 500MA
Battery:use the BL-5C battery
System:Windows 2000/XP/Vista/Windows 7,MAC OS x10.3.6 above
Dimensions/Weight: 119*55*13.2
Working temperature/humidity: 0~40oC / 10%~80%
Neutral Packing
Packing Weight:476g
Number:30pcs / ctn
Measurements:21*15*7.5Cm
Packing size :47*44*39CM
N.W:14.3kg /ctn
G.W:15.5kg /ctn
Цена-200 шек. Мой телефон-0526464940
[/img]
Video format: MJPG
Photos format: JPG
Power:5V 500MA
Neutral Packing
Packing Weight:476g
Number:30pcs / ctn
N.W:14.3kg /ctn
G.W:15.5kg /ctn
[/img]www.CampingLife.co.il
"На природу с комфортом!"
- grayswander
